[mapguide-users] ArcSDE FDO sucks !!!
Robert Fortin robert.fortin at autodesk.com
Tue Oct 7 15:57:38 EDT 2008
Shreepad,
As Jason said, it is not clear that this is a provider issue.  One issue was identified sometime ago related to invalid coordinate system handling in MG.  This issue was slowing down performance when coordinates system couldn't be mapped.  This was fixed in the recent MG code stream but I'm not sure it was backported in the code stream where you are seeing this problem.  I'm trying to contact the developer who look into this issue and see if we can get a hotfix or patch to try out.
I'm not sure that it will actually fix the problem you are seeing but it doesn't cost much trying it out.
I'll keep you posted.
RF
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of shreepad Ranadive
Sent: Monday, October 06, 2008 5:28 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] ArcSDE FDO sucks !!!
thanks jason
i will create a trac for this on fdo site.
I have tested this with  couple layers with new schema created its still
slow.
let me create trac to have it looked at by developers
thanks
shreepad
JasonBirch wrote:
> You may be asking on the wrong list if you want the FDO folks to
> respond.  Though I'm sure that some of them hang out here from time to
> time, fdo-users is a better place.  Might want to use a less
> inflammatory subject line though :)
> The problem may not be with the SDE provider though; I wonder if it is
> the same problem with initial schema load as has been seen with the
> RDBMS providers.  Does performance decrease as the number of tables
> stored in the SDE increases, or is it consistently slow?
> The best way to get this fixed is to clearly describe the problem,
> preferably with test data, in a Trac ticket.  Just saying that it is
> slow is not giving the developers enough to chew on.
> Jason
> From: shreepad Ranadive
> Subject: Re: [mapguide-users] ArcSDE FDO sucks !!!
> I found the same issue. the new fdos are bit slow with sde 9.1 /9.2
> i think some one from FDO team should take a look at it seriously
> FDO team : please have some reply to this request
> mapguide-users mailing list
Shreepad Ranadive
Direcotor , Application Development
ValueCAD
444 Natoma St
Sanfrancisco,CA 94103
View this message in context: http://www.nabble.com/ArcSDE-FDO-sucks-%21%21%21-tp19832086p19846802.html
