[mapguide-users] installing mapguide on server with php already on it
Dave Wilson dave.wilson at autodesk.com
Wed Oct 8 18:58:41 EDT 2008
What version of PHP is already installed. MapGuide only works with the installed version. PHP also doesn't play well side by side or support dual instances of near versions out of the box. This is documented on the PHP site. http://us.php.net/configuration
Are you installing on Windows or Linux.
Previous discussions in the list recommend adding the MapGuide PHP install directory to your system path (Windows).
You can also check your registry to see if the HKLM...entry points to the installed directory (Windows).
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of kawalski
Sent: Wednesday, October 08, 2008 3:19 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] installing mapguide on server with php already on it
i am trying to install mapguide on a server that is running IIS and already
has php installed.  i can not get the mapguide php pages to work.  i can't
get to the login page for adimistrator.  i have changed settings in IIS a
number of times to get .php to point to either of the php directories.  when
i removed the original php i could not get the other php pages to work by
pointing them to the mapguide version.  how do you get the 2 php's to play
together?
View this message in context: http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19880766.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
