[mapguide-users] installing mapguide on server with php already on it
kawalski jhagedorn at bannerassociates.com
Thu Oct 9 10:39:10 EDT 2008
so, if i remove the php directory under the mapguide directories and remove
the instance in PATH, then mapguide would look at the other php i already
have installed?  is there anything else that would need to be done to make
mapguide look to the other php?
thanks
Dave Wilson-3 wrote:
> Because you are using the same version, whichever is first in the path is
> likely to get used to set the php.ini when IIS loads. I don't believe you
> will get both of them to work. The registry entry also only points to one
> of the instances so again it's not really designed to allow both. A
> phpinfo page might help indicate which instance is getting loaded.
> You will likely have to decide which instance of PHP you wish to use and
> configure it for all the applications you need unless someone else has
> discovered a way to do this without recompiling php for their needs.
> Regards,
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of kawalski
> Sent: Thursday, October 09, 2008 7:17 AM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] installing mapguide on server with php
> already on it
> i have php 5.2.4 installed on the server.  i am on Windows.  both phps are
> in
> the PATH variable.
>> What version of PHP is already installed. MapGuide only works with the
>> installed version. PHP also doesn't play well side by side or support
>> dual
>> instances of near versions out of the box. This is documented on the PHP
>> site. http://us.php.net/configuration
>> Are you installing on Windows or Linux.
>> Previous discussions in the list recommend adding the MapGuide PHP
>> install
>> directory to your system path (Windows).
>> You can also check your registry to see if the HKLM...entry points to the
>> installed directory (Windows).
>> Dave
>> Sent: Wednesday, October 08, 2008 3:19 PM
>> Subject: [mapguide-users] installing mapguide on server with php already
>> on it
>> i am trying to install mapguide on a server that is running IIS and
>> already
>> has php installed.  i can not get the mapguide php pages to work.  i
>> can't
>> get to the login page for adimistrator.  i have changed settings in IIS a
>> number of times to get .php to point to either of the php directories.
>> when
>> i removed the original php i could not get the other php pages to work by
>> pointing them to the mapguide version.  how do you get the 2 php's to
>> play
>> together?
>> View this message in context:
>> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19880766.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19898310.html
View this message in context: http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19900334.html
