[mapguide-users] installing mapguide on server with php already on it
kawalski jhagedorn at bannerassociates.com
Fri Oct 10 12:16:04 EDT 2008
ok, i have at least been able to get to the login screen but get a 500 error
when i try to log in.  i have put the phpinfo() in the login php page and
everything is pointing to the correct directories.
thanks
Dave Wilson-3 wrote:
> Do a diff between the MapGuide php.ini and your existing on to see the
> changes that are required. There are only a couple of changes. You will
> also have to copy the additional php extension files included for mapguide
> to your directory. Again a diff between the directories might be the
> easiest way to go. I just don't know all the files off the top of my head.
> You then have to change the isapi mapping on the mapguide virtual
> directory in IIS to point to your instance.
> I think that's it.
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of kawalski
> Sent: Thursday, October 09, 2008 8:39 AM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] installing mapguide on server with php
> already on it
> so, if i remove the php directory under the mapguide directories and
> remove
> the instance in PATH, then mapguide would look at the other php i already
> have installed?  is there anything else that would need to be done to make
> mapguide look to the other php?
> thanks
>> Because you are using the same version, whichever is first in the path is
>> likely to get used to set the php.ini when IIS loads. I don't believe you
>> will get both of them to work. The registry entry also only points to one
>> of the instances so again it's not really designed to allow both. A
>> phpinfo page might help indicate which instance is getting loaded.
>> You will likely have to decide which instance of PHP you wish to use and
>> configure it for all the applications you need unless someone else has
>> discovered a way to do this without recompiling php for their needs.
>> Regards,
>> Dave
>> Sent: Thursday, October 09, 2008 7:17 AM
>> already on it
>> i have php 5.2.4 installed on the server.  i am on Windows.  both phps
>> are
>> in
>> the PATH variable.
>>> What version of PHP is already installed. MapGuide only works with the
>>> installed version. PHP also doesn't play well side by side or support
>>> dual
>>> instances of near versions out of the box. This is documented on the PHP
>>> site. http://us.php.net/configuration
>>> Are you installing on Windows or Linux.
>>> Previous discussions in the list recommend adding the MapGuide PHP
>>> install
>>> directory to your system path (Windows).
>>> You can also check your registry to see if the HKLM...entry points to
>>> the
>>> installed directory (Windows).
>>> Dave
>>> Sent: Wednesday, October 08, 2008 3:19 PM
>>> Subject: [mapguide-users] installing mapguide on server with php already
>>> on it
>>> i am trying to install mapguide on a server that is running IIS and
>>> already
>>> has php installed.  i can not get the mapguide php pages to work.  i
>>> can't
>>> get to the login page for adimistrator.  i have changed settings in IIS
>>> a
>>> number of times to get .php to point to either of the php directories.
>>> when
>>> i removed the original php i could not get the other php pages to work
>>> by
>>> pointing them to the mapguide version.  how do you get the 2 php's to
>>> play
>>> together?
>>> View this message in context:
>>> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19880766.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19898310.html
> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19900334.html
View this message in context: http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19921416.html
