[mapguide-users] ArcSDE FDO sucks !!!
Tony techswami at hotmail.com
Mon Oct 13 13:41:40 EDT 2008
Hi any one finally got any solution for ArcSDE.
shreepad: did you created any trac as jason suggested.
please guys lets have discussion on this as lot of MGOS sites are depend on
ArcSDE FDO.
tony
shreepad Ranadive wrote:
> the patch for ArcSDE !!  is talked in one  of the email links bellow.
> please
> let me know where can i download that and give it a shot
> shreepad
> Robert Fortin wrote:
>> Shreepad,
>> As Jason said, it is not clear that this is a provider issue.  One issue
>> was identified sometime ago related to invalid coordinate system handling
>> in MG.  This issue was slowing down performance when coordinates system
>> couldn't be mapped.  This was fixed in the recent MG code stream but I'm
>> not sure it was backported in the code stream where you are seeing this
>> problem.  I'm trying to contact the developer who look into this issue
>> and
>> see if we can get a hotfix or patch to try out.
>> I'm not sure that it will actually fix the problem you are seeing but it
>> doesn't cost much trying it out.
>> I'll keep you posted.
>> RF
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of shreepad
>> Ranadive
>> Sent: Monday, October 06, 2008 5:28 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: RE: [mapguide-users] ArcSDE FDO sucks !!!
>> thanks jason
>> i will create a trac for this on fdo site.
>> I have tested this with  couple layers with new schema created its still
>> slow.
>> let me create trac to have it looked at by developers
>> thanks
>> shreepad
>> JasonBirch wrote:
>>> You may be asking on the wrong list if you want the FDO folks to
>>> respond.  Though I'm sure that some of them hang out here from time to
>>> time, fdo-users is a better place.  Might want to use a less
>>> inflammatory subject line though :)
>>> The problem may not be with the SDE provider though; I wonder if it is
>>> the same problem with initial schema load as has been seen with the
>>> RDBMS providers.  Does performance decrease as the number of tables
>>> stored in the SDE increases, or is it consistently slow?
>>> The best way to get this fixed is to clearly describe the problem,
>>> preferably with test data, in a Trac ticket.  Just saying that it is
>>> slow is not giving the developers enough to chew on.
>>> Jason
>>> From: shreepad Ranadive
>>> Subject: Re: [mapguide-users] ArcSDE FDO sucks !!!
>>> I found the same issue. the new fdos are bit slow with sde 9.1 /9.2
>>> i think some one from FDO team should take a look at it seriously
>>> FDO team : please have some reply to this request
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Shreepad Ranadive
>> Direcotor , Application Development
>> ValueCAD
>> 444 Natoma St
>> Sanfrancisco,CA 94103
>> View this message in context:
>> http://www.nabble.com/ArcSDE-FDO-sucks-%21%21%21-tp19832086p19846802.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Shreepad Ranadive
> ValueCAD
> 444 Natoma St
> http://www.nabble.com/ArcSDE-FDO-sucks-%21%21%21-tp19832086p19904277.html
View this message in context: http://n2.nabble.com/ArcSDE-FDO-sucks-%21%21%21-tp1300054p1329651.html
