[mapguide-users] Oracle view crashing map server
btenbroeck btenbroeck at gmail.com
Tue Oct 14 06:31:16 EDT 2008
Hi Dragan
I don't have anything for you, other than to let you know we have run into
the same issue. View works fine under the Autodesk provider, or in Map, and
it is specific to a certain view. I posted in the FDO list back on 5/16, but
no resolution yet. Basically, I wanted to tie these two issues together.
Best regards,
Bill
Dragan Podvezanec wrote:
> Hi all.
> I followed instructions how to make layer from oracle view on Haris's
> site, and everything seemed ok, i managed to create few layers this way.
> But now I have one view which crashes the server everytime I turn the
> layer on, with following error:
> (3216) An unclassified exception occurred.
> Exception occurred in method
> MgApplicationRepositoryManager.EnumerateParentMapDe
> finitions at line 699 in file
> d:\buildforgeprojects\mapguide_open_source_v2.0\bu
> ild_27.16\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
> View has primary key, and table from which is created has spatial index,
> PK and all metadata set.
> Interrestingly, this layer shows ok using Autodesk Map3D and King.Oracle
> and I can even edit it. also, the table from which is created this view
> shows ok and doesn't throw any errors. But I need the view to show just
> last 5 records from the table. And this crashes mgserver. Any ideas?
View this message in context: http://www.nabble.com/Oracle-view-crashing-map-server-tp19952132p19970858.html
