Re[mapguide-users] nderingService on MGOS 2.0.2
Kenneth Skovhede, GEOGRAF A/S ks at
Thu Oct 16 04:27:42 EDT 2008
I use the GETMAPIMAGE function extensively, which I belive is the same
function, and it works great.
What line causes the error?
Have you tried with "PNG" instead of "png"?
Regards, Kenneth Skovhede, GEOGRAF A/S
Alex Fordyce skrev:
> Has anyone been successful using the RenderingService using release 2.0.2? It
> does not seem to be working for me. My install is MGOS 2.0.2 ,.NET, and IIS.
> I am trying to save a map as a PNG to my local drive.
> I get the following error: "An unclassified exception occurred." and no file
> is created. Yes, c:\temp exists. :)
> Sample C# code:
> MgByteReader byteReader = renderingService.RenderMap(map, selection,
> mapExtent, 650, 650, bgcolor, "png" );
> MgByteSink byteSink = new MgByteSink(byteReader);
> string fileName = "c:\\temp\\myMap.png";
> byteSink.ToFile(fileName);
> Any suggestions or success stories would be welcomed.
> thanks.
> alex
