[mapguide-users] Adding a point to a map... PLZ Help!!! (.NET -C#)
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Oct 16 04:38:21 EDT 2008
I agree with Maksim, there seems to be some confusion as to what you
want to do.
There are two basic scenarios:
1. You want to display some points based on context.
An example would be searching for hotels in a certain price interval,
and the opening a map with the hotels shown.
2. You want to display a number of points, but the data changes more or
less frequently.
An example of this would be position of vehicles.
A combination would be to show the position of vehicles that are using
diesel engines.
Could you elaborate on what your scenario is like?
Regards, Kenneth Skovhede, GEOGRAF A/S
Maksim Sestic skrev:
> Hmm, if you're attending to batch-process large number of points (along with
> attached data) then web service calling FDO directly will do it much more
> efficiently, since you can preset it on server side to poke exact
> datastore/schema (thus skipping enumeration). Especially if you're planning
> to parse some client-side file holding actual information. Other way round
> you'll be making too many client-server roundtrips.Of couse, it all depends
> on the overall setup...
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Galois
> Sent: Wednesday, October 15, 2008 16:29
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Adding a point to a map... PLZ Help!!! (.NET
> -C#)
> This is not a solution, cause at the feature, I'll have lot of XML files and
> the code will have to work in order to put all the interest points automatic
> on the map....
> ThanX anyway :-D
> Maksim Sestic wrote:
>> If the MG->Datastore approach is making you headaches, why don't you
>> directly access the datastore (i.e. via FDO if it's managed after all)
>> and store the point there "manually"? Of course, if you're poking it
>> from a client you'll have to establish a web service to do the job on
>> the server side. And don't forget to call MG refresh method from
>> JavaScript once you have that point within a datastore.
>> Regards,
>> Maksim Sestic
>> Sent: Wednesday, October 15, 2008 16:15
>> Subject: Re: [mapguide-users] Adding a point to a map... PLZ Help!!!
>> (.NET
>> -C#)
>> Maybe I'm stupid....
>> I cannot do it work. I have reconstruct the whole thing, but the new
>> Layer doesn't appear in the page.
>> I followed the Dev's Guide in order to create a Layer and add it in
>> the map but nothing.
>> Basically, I added these three functions. I really would appreciate if
>> u could give me some help..
>> public MgLayer addLayerRsc2Map(MgResourceIdentifier layerResId,
>> MgResourceService resourceSrvc, string layerName, string
>> layerLegendLabel, MgMap map)
>>         //MgLayer newLayer = new MgLayer(layerResId, resourceSrvc);
>>         MgLayer newLayer = new MgLayer(layerResId , resourceSrvc);
>>         //Add the new layer to the map's layer collection
>>         newLayer.SetName(layerName);
>>         newLayer.SetVisible(true);
>>         newLayer.SetLegendLabel(layerLegendLabel);
>>         newLayer.SetDisplayInLegend(true);
>>         MgLayerCollection layerCollection = map.GetLayers();
>>         if( !layerCollection.Contains(layerName) )
>>             //Insert the new layer to position 0 so it is at
>>             //the top of the drawing order
>>             layerCollection.Insert(0,newLayer);
>>         MgLayerGroupCollection skata = map.GetLayerGroups();
>>         return newLayer;
>>     public MgLayer addLayerDef2Map(string layerDefinition, string
>> layerName, string layerLegendLabel, string sessionId,
>> MgResourceService resourceSrvc, MgMap map )
>>         // Adds the layer definition (XML) to the map.
>>         // Returns the layer.
>>         //Validate the XML.
>>         XmlDocument domDocument = new XmlDocument();
>>         domDocument.LoadXml(layerDefinition);
>>         domDocument.PreserveWhitespace = true;
>>         MemoryStream stream = new System.IO.MemoryStream();
>>         domDocument.Save(stream);
>>         Byte[] byteArray = stream.ToArray();
>>         string outerXml =
>> System.Text.Encoding.UTF8.GetString(byteArray,
>> 0,
>> byteArray.Length);
>>         byteArray = System.Text.Encoding.UTF8.GetBytes(outerXml);
>>         //Save the new layer definition to the Session.
>>         MgByteSource byteSource = new MgByteSource(byteArray ,
>> byteArray.Length);
>>         byteSource.SetMimeType(MgMimeType.Xml);
>>         MgResourceIdentifier resourseId = new
>> MgResourceIdentifier("Session:" + map.SessionId + "//" + layerName +
>> "." + MgResourceType.LayerDefinition);
>>         // Set the map with the new resource
>>         resourceSrvc.SetResource(resourseId, byteSource.GetReader(),
>> null);
>>         MgLayer newLayer = addLayerRsc2Map(resourseId, resourceSrvc,
>> layerName, layerLegendLabel, map);
>>         return newLayer;
>>     public void addLayer2Group(MgLayer layer, string layerGroupName,
>> string layerGroupLegendLabel, MgMap map)
>>     // Adds a layer to a layer group. If necessary, it creates
>>     // the layer group.
>>         //Get the layer group
>>         MgLayerGroup layerGroup;
>>         MgLayerGroupCollection layerGroupCollection =
>>         if( layerGroupCollection.Contains(layerGroupName) )
>>             layerGroup = layerGroupCollection.GetItem(layerGroupName);
>>         else
>>             //It does not exist, so create it.
>>             layerGroup = new MgLayerGroup(layerGroupName);
>>             layerGroup.SetVisible(true);
>>             layerGroup.SetDisplayInLegend(true);
>>             layerGroup.SetLegendLabel(layerGroupLegendLabel);
>>             layerGroupCollection.Add(layerGroup);
>>         //Add the layer to the group.
>>         layer.SetGroup(layerGroup);
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>> Did you look at the buffer sample code in the AJAX viewer?
>>> It does exactly what is required, besides inserting your points.
>>> About your code:
>>> You do not use the "resourceIdentifier" variable, which means your
>>> layer might reference something else.
>>> You save the layers to the regular repository, which is fine, but
>>> each use will overwrite the previous copy, making it impossible to
>>> reliably serve more than one user.
>>> You do not add the layer to the runtime map, and you do not save the
>>> runtime map.
>>> You write: "I just want to display them".
>>> Well, MapGuide works by displaying data from a FeatureSource, styled
>>> through a LayerDefinition.
>>> You cannot insert data in the LayerDefinition, it must be in a
>>> FeatureSource.
>>> If you insert the data in an existing FeatureSource, with an existing
>>> layer, that is fine too, but I cannot guess that is what you want.
>>> You did not mention an Xml file with points before, just a single point.
>>> Depending on your data, you may want to insert them into a database
>>> (like Sqlite or Access), or into an SDF file.
>>> If you choose the database version, your FeatureSource can be of type
>>> ODBC.
>>> If you use a database, you can insert the points using regular SQL
>>> queries against the database.
>>> If the points are persistent (that is, not tied to a particular users
>>> map, like session values), you can just create a FeatureSource +
>>> Layer through Maestro or Studio without requirering any code.
>>> If you are looking to create something similar to "Points of interrest"
>>> with a nice little flag, you might
>>> consider using OpenLayers instead of the AJAX viewer:
>>> http://www.openlayers.org/
>>> http://www.openlayers.org/dev/examples/georss-markers.html
>>> (OpenLayers also supports MapGuide as the backend server)
>>> Galois skrev:
>>>> First of all, thank u fro your reply.
>>>> I don't get why should I create a temp layer.
>>>> I have some coordinates in an XML file, and I just want to display
>>>> them on an existing layer.
>>>> Though I tried to create a new layer, it does not appear in my maps
>>>> layers.
>>>> That's what I did...
>>>> MgResourceIdentifier resourceIdentifier = new
>>>> MgResourceIdentifier("Library://GoSpatial/Data/airports.FeatureSource");
>>>>         MgResourceIdentifier layerResId = new
>>>> MgResourceIdentifier("Library://GoSpatial/Layers/TmpLayer.LayerDefin
>>>> i
>>>> tion");
>>>>         string layerDefinition =
>>>> File.ReadAllText("C:/Inetpub/wwwroot/iwaygis/TmpLayer.LayerDefinitio
>>>> n
>>>> .xml");
>>>>         MgByteReader reader = new MgByteReader(layerDefinition,
>>>> "text/xml");
>>>>         resourceSrvc.SetResource(layerResId, reader, null);
>>>>         tmpLayer = new MgLayer(layerResId, resourceSrvc);
>>>>         tmpLayer.SetName("TempLayer");
>>>>         tmpLayer.SetLegendLabel("TempLayer");
>>>>         tmpLayer.SetDisplayInLegend(true);
>>>>         tmpLayer.SetSelectable(true);
>>>>         MgLayerCollection layers = map.GetLayers();
>>>>         layers.Insert(0, tmpLayer);
>>>>         tmpLayer.SetVisible(true);
>>>>         tmpLayer.ForceRefresh();
>>>> Thx!
>>>>> A few steps are involved:
>>>>> 1. Create a temporary featuresource 2. Create a temporary layer to
>>>>> display the features 3. Insert the temporary layer into the runtime
>>>>> map
>>>>> The buffer files in the MapGuide viewer has template code for all
>>>>> three steps.
>>>>> All steps are explained in the Developer Guide (PDF version at least).
>>>>> You might also want to look here:
>>>>> http://trac.osgeo.org/mapguide/wiki/CodeSamples/ASP.Net/ScribbleApp
>>>>> Galois skrev:
>>>>>> Hello,
>>>>>> I´m trying to add a point to a map but I have no idea how to it.
>>>>>> I have declare the map object, and also I create a point with it's
>>>>>> coordinates.
>>>>>> But I don't know what is the next step that I have to do...
>>>>>> The code follows....
>>>>>> public partial class _Default : System.Web.UI.Page {
>>>>>>     public string sessionId;
>>>>>>     public string webLayout;
>>>>>>     protected void Page_Load(object sender, EventArgs e)
>>>>>>         string physicalPath = @"C:\Program
>>>>>> Files\MapGuideOpenSource\WebServerExtensions\www\webconfig.ini";
>>>>>>         try
>>>>>>             MapGuideApi.MgInitializeWebTier(physicalPath);
>>>>>>             passAndSession();
>>>>>>             //Associate a session ID with the MgSiteConnection Object
>>>>>>             MgUserInformation userInfo_new = new
>>>>>> MgUserInformation(sessionId);
>>>>>>             MgSiteConnection siteConnection = new
>>>>>> MgSiteConnection();
>>>>>>             siteConnection.Open(userInfo_new);
>>>>>>             MgResourceService resourceSrvc =
>>>>>> (MgResourceService)siteConnection.CreateService(MgServiceType.Reso
>>>>>> u
>>>>>> rceService);
>>>>>>             MgMap map = new MgMap(siteConnection);
>>>>>>             webLayout =
>>>>>> "Library://GoSpatial/Web+Layouts/Autostrada+Brescia+Padova+Map.Web
>>>>>> L
>>>>>> ayout";
>>>>>>             MgResourceIdentifier resId = new
>>>>>> MgResourceIdentifier("Library://GoSpatial/Maps/Italy
>>>>>> Map.MapDefinition");
>>>>>>             String mapName = resId.GetName();
>>>>>>             MgResourceIdentifier mapStateId = new
>>>>>> MgResourceIdentifier("Session:" + sessionId + "//" + mapName + "."
>>>>>> + MgResourceType.Map);
>>>>>>             map.Create(resourceSrvc, resId, mapName);
>>>>>>             map.Save(resourceSrvc, mapStateId);
>>>>>>             map.Open(resourceSrvc, mapName);
>>>>>>             createPoint();
>>>>>>         catch (Exception ex)
>>>>>>             throw (ex);
>>>>>>     public string passAndSession()
>>>>>>         MgUserInformation userInfo = new
>>>>>> MgUserInformation("Administrator",
>>>>>> "admin");
>>>>>>         MgSite site = new MgSite();
>>>>>>         site.Open(userInfo);
>>>>>>         sessionId = site.CreateSession();
>>>>>>         return sessionId;
>>>>>>     public MgPoint createPoint()
>>>>>>         MgGeometryFactory geometryFactory = new
>>>>>> MgGeometryFactory();
>>>>>>         MgCoordinateXY coordinate = (MgCoordinateXY)
>>>>>> geometryFactory.CreateCoordinateXY(10.913161, 45.408046);
>>>>>>         MgPoint point = geometryFactory.CreatePoint(coordinate);
>>>>>>         return point;
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/Adding-a-point-to-a-map...-PLZ-Help%21%21%21-%28
>> .NET--
>> -C-%29-tp19954532p19994399.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> __________ Information from ESET NOD32 Antivirus, version of virus
>> signature database 3523 (20081015) __________
>> The message was checked by ESET NOD32 Antivirus.
>> http://www.eset.com
> http://www.nabble.com/Adding-a-point-to-a-map...-PLZ-Help%21%21%21-%28.NET--
> -C-%29-tp19954532p19994711.html
> __________ Information from ESET NOD32 Antivirus, version of virus signature
> http://www.eset.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081016/12398246/attachment.html
