[mapguide-users] Generate map tiles from Oracle data
gingerbbm stuart.jones at jacobs.com
Thu Oct 16 06:54:20 EDT 2008
gingerbbm wrote:
> My next question is whether MapGuide will use the same set of tiles for
> base layers that are referenced in several different map definitions. I
> assume it will... can somebody confirm this?
Well I've had a look in the Repositories/TileCache folder and it's obvious
that this is not the case. This means that for each project with the same
base layers we're going to have to have a distinct copy of the tiles. Is
there any way around this duplication?
View this message in context: http://n2.nabble.com/Generate-map-tiles-from-Oracle-data-tp1336571p1340619.html
