Re[mapguide-users] nderingService on MGOS 2.0.2
Zac Spitzer zac.spitzer at gmail.com
Thu Oct 16 20:46:17 EDT 2008
there's a few case sensitive gotcha's like that with mapguide...
worth filing a bug?
On Fri, Oct 17, 2008 at 11:41 AM, Alex Fordyce <afordyce at ix.netcom.com> wrote:
> Kenneth,
> I don't know whether to laugh or cry, but that was it! Changed "png" to
> "PNG" and it works great now.
> Thank you so much.
> Regards,
> alex
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I use the GETMAPIMAGE function extensively, which I belive is the same
>> function, and it works great.
>> What line causes the error?
>> Have you tried with "PNG" instead of "png"?
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Alex Fordyce skrev:
>>> Has anyone been successful using the RenderingService using release
>>> 2.0.2? It
>>> does not seem to be working for me. My install is MGOS 2.0.2 ,.NET, and
>>> IIS.
>>> I am trying to save a map as a PNG to my local drive.
>>> I get the following error: "An unclassified exception occurred." and no
>>> file
>>> is created. Yes, c:\temp exists. :)
>>> Sample C# code:
>>> MgByteReader byteReader = renderingService.RenderMap(map, selection,
>>> mapExtent, 650, 650, bgcolor, "png" );
>>> MgByteSink byteSink = new MgByteSink(byteReader);
>>> string fileName = "c:\\temp\\myMap.png";
>>> byteSink.ToFile(fileName);
>>> Any suggestions or success stories would be welcomed.
>>> thanks.
>>> alex
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/RenderingService-on-MGOS-2.0.2-tp20005723p20023938.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
