[mapguide-users] Print Layout - 2 questions...
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Oct 17 03:58:19 EDT 2008
Yes, you can specify DPI in the querystring with the parameter DPI.
There are no PDF tools present in MapGuide, so you would have to build
that yourself, or use a thirdparty PDF library.
The image you can get from MapGuide is a plain image, and can easily be
inserted into a PDF or other document.
You can see the querystring for on, if you right click on a map image in
the "Print preview".
Regards, Kenneth Skovhede, GEOGRAF A/S
BradM skrev:
> With respect to printing,  can we print to PDF and can we specify the DPI so
> that images will print with a higher resolution?
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> To the best of my knowledge, Print Layouts are only avalible when used
>> with the DWF viewer.
>> I am, as always, happy to be corrected, should I be wrong.
>> Printing features in the AJAX viewer are basically a template HTML page
>> with placeholders for the map and legend.
>> You can modify printablepage.templ to issue site wide changes.
>> You can usually ask any question you want here, but you cannot expect a
>> reply.
>> I assume you can expect a reply on the Autodesk pages, if you paid for
>> Autodesk support.
>> stoff skrev:
>>> Hi Kenneth, hi Warren!
>>> ...just to be sure:
>>> Is it true that the Mapguide Studio Printlayouts are only to use
>>> within the dwf viewer (and its activeX-features)?
>>> To have a customized printlayout in the mapguide ajax standard viewer
>>> I have to modify the printablepage.templ?
>>> And this pertains topobase web in the same manner, doesn't it?
>>> Just a big suprise, because the Users Guide does not really gives hints
>>> on
>>> this ...
>>> Best regards and thank you in advance,
>>> stoff javascript:Nabble.smiley('anim_confused.gif',':confused:')
>>> Is it okay, to ask this here or do I have to ask it only in the autodesk
>>> discussion group?
>>> Warren Medernach wrote:
>>>> Perfect!
>>>> Thanks for the info Kenneth.
>>>> Warren M
>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
>>>> Sent: Friday, October 03, 2008 11:54 AM
>>>> To: MapGuide Users Mail List
>>>> Subject: Re: [mapguide-users] Re: Print Layout - 2 questions...
>>>> Not sure if he got the answers, but here they are:
>>>> 1. You must change it in ajaxmappane.templ (line 293):
>>>> Look for:
>>>> var us = true;
>>>> and change to:
>>>> var us = false;
>>>> You have to change this every time update your MapGuide installation.
>>>> 2. There is no built in way to do this, you must modify
>>>> printablepage.templ.
>>>> Its a HTML file that gets sent to the browser with the map items
>>>> injected.
>>>> You can set a logo anywhere on the page using some html:
>>>> If you want different printable pages for different solutions, you have
>>>> to modify
>>>> at least printablepageui.templ.
>>>> Again, you have to change this every time update your MapGuide
>>>> installation.
>>>> The files I mention are all located in:
>>>> C:\Program
>>>> files\MapGuideOpenSource2.0\WebServerExtensions\www\viewerfiles
>>>> Warren Medernach skrev:
>>>> Hi Andrew,
>>>> Were you ever able to resolve this print layout issue?
>>>> Warren M
>>>> 	I've got 2 questions about PrintLayouts....1) How do I make my
>>>> units
>>>> metres? I've got >every instance of <units> set to metres in my
>>>> PrintLayout, and yet my scale bar insists >that the units are feet. 2)
>>>> How the heck do you get a custom logo?? It seems so simple, >but I can't
>>>> get it to work for the life of me....I've got a symbol library called
>>>> 	"Logo", and in it there is one symbol called "Gemlogo-smaller".
>>>> I've
>>>> tried all sorts of >variations on ResourceIDs, but can't get it.
>>>> 	Andrew
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> :confused:
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081017/2b722d20/attachment.html
