[mapguide-users] New to MapGuide OS
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Oct 17 10:54:30 EDT 2008
You also have to select .Net 2.0 under properties->ASP.Net in IIS.
Regards, Kenneth Skovhede, GEOGRAF A/S
Berdel, Brian skrev:
> You need to copy the dll's from the mapviewernet bin directory to the
> bin directory of your site.
> Brian
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Nelson Soto
> *Sent:* Friday, October 17, 2008 10:23 AM
> *To:* MapGuide Users Mail List
> *Subject:* RE: [mapguide-users] New to MapGuide OS
> I am having a .NET related error when trying to load the .NET ajax
> viewer sample...
> It is a rudimentary error. I can not load the namespace
> OSGeo.MapGuide. Does this mean I need to reinstall MapGuide or have I
> missed an additional step? I believe I installed both MapGuide and
> WebServerExtensions and am also under the impression I selected the
> .NET part of the configuration during install..
> *Sent:* Friday, October 17, 2008 10:16 AM
> Indeed, I just recognized this! Thanks for the prompt responses!
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* Friday, October 17, 2008 10:11 AM
> *Subject:* Re: [mapguide-users] New to MapGuide OS
> You are most likely using IE, which has renamed the Sheboygan.mgp file
> til Sheboygan.zip.
> Rename it back, and you can load it.
> Nelson Soto skrev:
> Ok, so at the risk of sounding a bit naïve, I am at the point where I
> have dropped the Sheboygan Sample Data in the folder "Packages" in the
> Server install directory. When logged into the Admin Site however, it
> does not list any packages as being present to load.
> I am using IIS 5.1, which I have read may pose issues down the line
> with a maximum connection limit (although I think I can circumvent
> that...).
> The package path in the configuration is 'C:/Program
> Files/MapGuideOpenSource2.0/Server/Packages/' which is the correct
> path. Has anyone ever run into a similar situation?
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> *Sent:* Friday, October 17, 2008 9:58 AM
> This was not what I had looked at, I think I was looking throught the
> dev PDF. This is exactly what I was looking for I believe. Thank you!
> *Sent:* Friday, October 17, 2008 9:54 AM
> Was one of the PDF's the "Gettings Started with MapGuide":
> http://mapguide.osgeo.org/2.0/documentation.html
> If so, which of the five steps on page 1 is causing you trouble?
> Nelson Soto skrev:
> Hello all,
> I have experience with MapServer but just discovered MapGuide as a
> seeming alternative... I would like to get the samples running but I
> am quite clueless. I am attempting to read the PDF help but it doesn't
> seem to help me get the demo's up and running or I am kind of an
> imbecile. Can anyone guide me to a tutorial or instructions on how to
> set up the samples, I guess Sheboygan?
> Thanks,
> Nelson
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081017/3f7feb43/attachment.html
