[mapguide-users] RE: MapGuide Open Source Web Studio
Zac Spitzer zac.spitzer at gmail.com
Mon Oct 20 12:24:33 EDT 2008
Have you reported the crash with Maestro? http://trac.osgeo.org/mapguide/
You can always use the api to write your own code to upload files into
the repository
There is a free trial version of mapguide studio available which is
relatively cheap,
especially given the what you can achieve using it authoring. ArcSDE isn't
exactly cheap either :) plus you are supporting Autodesk who fund most
(if not all)
of the development of MapGuide.
z
On Tue, Oct 21, 2008 at 3:01 AM, Nelson Soto <NSoto at plotplans.com> wrote:
> That's unfortunate because Maestro crashes on me rather often... Is
> there no other alternative to adding data? This might be a deal breaker
> if I must shell out money for Autodesk's Web Studio just to get a
> working way of adding data...
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Monday, October 20, 2008 11:11 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] RE: MapGuide Open Source Web Studio
> try maestro, webstudio never fully got the love it needed
> z
> On Tue, Oct 21, 2008 at 1:32 AM, Nelson Soto <NSoto at plotplans.com>
> wrote:
>> Sorry, to be more specific, for all except for Map Panels - Layers, I
> get a
>> 404 not found error in the section where the Help Contents Displays.
>> The error 500 appears as a Javascript MsgBox.
>> ________________________________
>> From: Nelson Soto
>> Sent: Monday, October 20, 2008 10:30 AM
>> To: 'MapGuide Users Mail List'
>> Subject: MapGuide Open Source Web Studio
>> For some reason, I can not upload SHP following the Getting Started
> options
>> @ http://localhost/mapguide/webstudio/index.html#
>> When looking at the "Help Guide" with "Help Topics"  the following
> sections
>> do not load:
>> Concepts
>> a)       Feature Source
>> b)      Layer
>> c)       Map
>> Panels
>> a)       Feature Source Panels - Properties
>> b)      Feature Source Panels - Settings
>> c)       Map Panels - Layers (Blank?)
>> Sometimes, an error 500 appears other times it does not. What do I do?
>> Thanks,
>> Nelson
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
