[mapguide-users] After adding shape files with Maestro, layers, map, etc.
Nelson Soto NSoto at plotplans.com
Mon Oct 20 15:50:45 EDT 2008
I was able to get I to work by replacing the Library variable in the
dotnetviewersample. Previewing the asplayout from Maestro seems to give
me a 'login required' error so this is the way I've been proceeding thus
far. thanks
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Monday, October 20, 2008 3:45 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] After adding shape files with Maestro,
layers, map, etc.
I think you have to restart the MapGuide service after adding an alias,
but I'm not sure.
For starters, you can also enter the absolute path manually (keep in
mind that it is the path as it looks on the server).
I have used SHP data without setting the temp folder.
I have not used FlexibleLayouts, so I can only guess that the Fusion
templates do not correlate with your map list in some way.
You can try to create a WebLayout and add the map to that one, that will
at least tell you if the error is in Fusion.
Regards, Kenneth Skovhede, GEOGRAF A/S
Nelson Soto skrev:
I basically copied most of the Sheboygan stuff, including the
FlexibleLayouts, but supplemented the things I saw Sheboygan reference
with my sample data. When trying to preview the map via the
FlexibleLayouts, I get the layout but no data. A JS error occurs saying
Error Line 120: 'maps' is null or not an object.
So, I'm assuming I haven't set something up correctly.
For my SHP connections, must I set up a temp dir? I have tried to set up
an Alias  to a tempdir but Maestro keeps telling me there are no aliases
set despite that I went through Web Site Admin and set one up. The
settings through Web Admin were saved successfully.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081020/2b9c19d3/attachment.html
