[mapguide-users] Services API: 'SelectFeatures' can't accept null properties?
Mauricio Villablanca mgvillablanca at yahoo.com
Mon Oct 20 15:53:50 EDT 2008
The same issue happens in Mapguide Enterprise 2009 and I hope it will be
fixed soon. I work with a database that has a lot of null attributes and
querying data by attribute is unreliable.
Jackie Ng wrote:
> I believe it is because the MgFeatureReader now throws exceptions when
> accessing null values and that the http handler hasn't been updated to
> check
> for nulls first.
> I've already made a ticket for this issue here:
> http://trac.osgeo.org/mapguide/ticket/708
> - Jackie
> Carl wrote:
>> I tried Services API 'SelectFeatures' of 'Feature' on
>> http://localhost/MapGuide/mapagent/index.html.
>> fill the Resource id with a MS SQL Server 2008 feature source
>>     the Class name with a table name
>> and left other field as default.
>> the return is as follows:
>> Value for Prj_SpatialData property is null.
>> Value for Prj_SpatialData property is null. Exception occurred in method
>> MgNullableProperty.CheckNull at line 73 in file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\common\foundation\Data/NullableProperty.cpp
>> Prj_SpatialData is of nullable varchar(MAX) field.
>> When I manually update Prj_SpatialData='', OK, no error messages shown.
>> I tried several tables. Once one table contains a row with null field
>> value, the above message will be shown.
>> It seems SelectFeatures can't accept the null field value. If so, is it a
>> bug?
> http://themapguyde.blogspot.com
> http://www.linkedin.com/in/jackieng
> http://www.nabble.com/Services-API%3A-%27SelectFeatures%27-can%27t-accept-null-properties--tp20057379p20059721.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Services-API%3A-%27SelectFeatures%27-can%27t-accept-null-properties--tp1352046p1356893.html
