[mapguide-users] Map Busy
Akram akram at gsg-eg.com
Tue Oct 21 08:19:42 EDT 2008
Hi all;
To put animated GIF related with your map busy if (False or True)
you can use two methods
(For Map Only)
1.in your main page which contain Map iframe put Div with id = "divRefresh"
as following
<div id="divRefresh" name="divRefresh" class="cssRefresh" style="...YOUR
STYLE...">
  ....YOUR IMAGE....
 </div>
2.in viewerfiles/ajaxmappane.templ edit the two functions (OnMapLoading) and
(OnMapLoaded) by replace the folloing lines
var frmParent = parent.frames["tbFrame"];
var objDivRefresh = frmParent.document.getElementById("divRefresh");
To
var objDivRefresh = parent.parent.document.getElementById("divRefresh");
(For whole page loading)
2.use following script
tryAgain();
function tryAgain()
frame=document.getElementById("mapFrame");
if(frame.document.readyState=="complete")
document.getElementById('myimg').style.visibility = 'hidden';
else
setTimeout("tryAgain()",100);
I hope it is useful ..........
http://gsg-eg.com
http://n2.nabble.com/file/u111068/head2.jpg
GeoService
View this message in context: http://n2.nabble.com/Map-Busy-tp1359322p1359322.html
