[mapguide-users] Map Busy
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Oct 21 08:36:50 EDT 2008
Hi Akram.
There exists a page where you can share such samples with others:
http://trac.osgeo.org/mapguide/wiki/CodeSamples
It would be great if you were to create a new page, and insert your example.
Regards, Kenneth Skovhede, GEOGRAF A/S
Akram skrev:
> Hi all;
> To put animated GIF related with your map busy if (False or True)
> you can use two methods
> (For Map Only)
> 1.in your main page which contain Map iframe put Div with id = "divRefresh"
> as following
> <div id="divRefresh" name="divRefresh" class="cssRefresh" style="...YOUR
> STYLE...">
>   ....YOUR IMAGE....
>  </div>
> 2.in viewerfiles/ajaxmappane.templ edit the two functions (OnMapLoading) and
> (OnMapLoaded) by replace the folloing lines
> var frmParent = parent.frames["tbFrame"];
> var objDivRefresh = frmParent.document.getElementById("divRefresh");
> To
> var objDivRefresh = parent.parent.document.getElementById("divRefresh");
> (For whole page loading)
> 2.use following script
> tryAgain();
> function tryAgain()
> frame=document.getElementById("mapFrame");
> if(frame.document.readyState=="complete")
> document.getElementById('myimg').style.visibility = 'hidden';
> else
> setTimeout("tryAgain()",100);
> I hope it is useful ..........
> http://gsg-eg.com
> http://n2.nabble.com/file/u111068/head2.jpg
> GeoService
