[mapguide-users] Zac's tile seeder with British National Grid
gingerbbm stuart.jones at jacobs.com
Tue Oct 21 12:31:36 EDT 2008
Dear all
I got Zac's tile seeder working with Sheboygan using both of the following:
http://trac.osgeo.org/mapguide/attachment/wiki/CodeSamples/Tiles/TileCacheSeeding/mapguide_tile_seeder.html
http://trac.osgeo.org/mapguide/attachment/wiki/CodeSamples/JavaScript/OpenlayersExample/sheboygan.php
But I can't convert either to work with my tiled map using British National
Grid coordinates.
I've changed my Bounds like this:
    var extent = new OpenLayers.Bounds(302000,370000,375000,410000);
I've tweaked the mapOptions thus:
    var mapOptions = {
        units: 'm',
        projection: 'EPSG:27700',
And I added these lines (as stated
http://zacster.blogspot.com/2008/08/tiny-little-openlayers-mapguide-fusion.html
in Zac's blog ):
    var metersPerUnit = 111319.4908;  //value returned from mapguide
    var inPerUnit = OpenLayers.INCHES_PER_UNIT.m * metersPerUnit;
    OpenLayers.INCHES_PER_UNIT["dd"] = inPerUnit;
    OpenLayers.INCHES_PER_UNIT["degrees"] = inPerUnit;
I'm suspicious about the hard-coded tempScales values. As I have no previous
experience with OpenLayers, perhaps there's something obvious I've not done.
Any ideas, anyone?
Thanks
Stuart
View this message in context: http://n2.nabble.com/Zac%27s-tile-seeder-with-British-National-Grid-tp1360223p1360223.html
