[mapguide-users] error 1053
Dave Wilson dave.wilson at autodesk.com
Tue Oct 21 14:48:43 EDT 2008
The mapguide service will fail to start if your system is slow at starting other services. Often times defragging your c drive will speed your boot process and allow these services to start as expected on a reboot.
In this case you problem may be something else.
Can you try running the mgserver2009.exe from a command line with the /run parameter and see if you get an error.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nandorov
Sent: Tuesday, October 21, 2008 11:46 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] error 1053
hi,
i have a problem with my mapguide service. it's down and when i'm trying to
start the service i get the following error "error 1053:the service did not
respond to the start or control request in a timely fashion".
i'm using windows xp sp 2
how can i fix it?
thanks
View this message in context: http://www.nabble.com/error-1053-tp20095659p20095659.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
