[mapguide-users] Shapefile Features Not Rendering
GISDOTNET aaron.ford at ntierdigm.com
Tue Oct 21 23:17:40 EDT 2008
I have a MGOS 2.0.1 application running based on ESRI shapefiles. We are
using Autodesk MapGuide Enterprise Studio for our layer and map creation.
The issues I am experiencing are twofold:
1.) Some of the shapefiles do not fully render all of their features
depending on scale e.g. at start up not all the parcel polygons are drawn.
If I zoom into that area the features draw. Additionally, they can be
searched on and selected even though they are not displayed. There are no
scale limitations or other restrictions applied to these layers. Even with
all the other layers turned off less the affected layers, the problem still
persists.
2.) How are people handling annotation from ESRI data sources? All our data
is in SDE; however, we had significant display/rendering issues which lead
to dropping everything to shapefiles. As a result, we are experiencing
difficulty having all the annotation converted to labeled lines render in
our MGOS application.
We are very excited to make the move to MGOS from ArcIMS, but very
frustrated with not being able to display our native data in either SDE or
exported shapefiles. We have even gone as far to re-index the troubled
shapefiles after they are exported and still experience the same issue.
Note, this is not an issue rendering these files in ArcView or ArcIMS. Is
there a limit on the number of features that MGOS will render or geometry
that it has trouble rendering?
I hope this is a simple fix and can supply representative shapefiles for
others to review and reproduce this issue.
Thank you!
Aaron
View this message in context: http://www.nabble.com/Shapefile-Features-Not-Rendering-tp20103332p20103332.html
