[mapguide-users] How To Routine and many question - Mapguide maestro..
AmyN amy.norcott at cardno.com.au
Wed Oct 22 01:23:53 EDT 2008
I can answer part 6 of your question... i'm guessing it's the same though
i've never used Maestro
To set up a query, you need to have the data loaded into mapguide. To find
the address your best bet is to have an address field calculated in the
cadastral layer, or a points layer (hopefully your area isn't too large, or
you  might be better off setting a query just to search street name.
The details for the address will need to be all in one field e.g. "34 Sommes
Ave Katoomba" because mapguide can't query multiple fields at once (not last
i checked anyway).
To set up a query create a custom command > Search
Then you can tell MG which layer to search in and pass the search through
the filter: Address LIKE '$USER_VARIABLE%'
You can also define fields that will show up in the results e.g. Lot/DP and
Address etc.
Then you need to add the new command that you created to the toolbar in your
viewer.
Cheers
Amy Norcott
GIS Analyst
Wollongong, Australia
View this message in context: http://www.nabble.com/How-To-Routine-and-many-question---Mapguide-maestro..-tp20104104p20104188.html
