[mapguide-users] Shapefile Features Not Rendering
Jason Birch Jason.Birch at nanaimo.ca
Wed Oct 22 11:39:06 EDT 2008
Hi Aaron,
Your first issue may be due to a defect in the AGG renderer that does
not display some features at small scales.
http://trac.osgeo.org/mapguide/ticket/632
Try switching the renderer to GD in your serverconfig.ini file and
restarting the MapGuide service to see if that's the case.
Can't offer any guidance on the second issue... what kind of difficulty
are you having?  Is MapGuide's collision detection hiding some of the
annotation?
Jason
-----Original Message-----
Subject: [mapguide-users] Shapefile Features Not Rendering
1.) Some of the shapefiles do not fully render all of their features
depending on scale e.g. at start up not all the parcel polygons are
drawn.
[snip]
2.) How are people handling annotation from ESRI data sources? All our
data
is in SDE; however, we had significant display/rendering issues which
lead
to dropping everything to shapefiles. As a result, we are experiencing
difficulty having all the annotation converted to labeled lines render
in
our MGOS application.
