[mapguide-users] Cyrillic alphabet/Encoding problem
milko_velichkov milko_do at abv.bg
Fri Oct 24 01:52:04 EDT 2008
Unfortunately that's doesn't work in my case :(
http://www.nabble.com/file/p20144623/t.jpeg
Traian Stanev wrote:
> Yes, SHP files and encodings is trouble... You can try to force the
> encoding to UTF-8 by adding a .CPG file alongside your SHP file (with the
> same filename as the .SHP). The contents should be a single line of text,
> saying "UTF-8", without the quotes. This will hint the FDO provider for
> SHP files to use that encoding. No guarantee that would fix it though...
> Another thing you can do to identify the cause of the problem is try to
> use a constant Cyrillic string as a label for your geometry. If that shows
> up fine in MapGuide, then the problem is upstream (in the FDO provider),
> otherwise it's a problem in the MapGuide code.
> Traian
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>> bounces at lists.osgeo.org] On Behalf Of milko_velichkov
>> Sent: Thursday, October 23, 2008 1:32 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: RE: [mapguide-users] Cyrillic alphabet/Encoding problem
>> Under "Selection" tab, when I have attribute information in Cyrillic
>> from a
>> SHP data source, they appear like маймуница :). Same with all labels
>> within
>> the Map window. Encoding used by default is UTF-8 (I don't have an idea
>> how
>> to change it within the MapGuide environment).
>> Milko
>> > What exactly is the problem you are seeing? Also, are you using
>> Unicode or
>> > some other encoding for the Cyrillic in your data source?
>> > Traian
>> >> Sent: Wednesday, October 22, 2008 4:26 AM
>> >> Subject: [mapguide-users] Cyrillic alphabet/Encoding problem
>> >> Hi,
>> >> Did anyone else has a problem with the visualization/encoding of
>> >> Cyrillic
>> >> letters when selecting features from within MapGuide?
>> >> View this message in context: http://www.nabble.com/Cyrillic-
>> alphabet-
>> >> Encoding-problem-tp20104783p20104783.html
>> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> >> _______________________________________________
>> >> mapguide-users mailing list
>> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context: http://www.nabble.com/Cyrillic-alphabet-
>> Encoding-problem-tp20104783p20124621.html
View this message in context: http://www.nabble.com/Cyrillic-alphabet-Encoding-problem-tp20104783p20144623.html
