[mapguide-users] google maps as base layer
Paul Spencer pagameba at gmail.com
Fri Oct 24 07:04:50 EDT 2008
I don't know what is in the 2009 update but I do know that the 2.0.2
update did NOT include Fusion 1.1 and it doesn't take a lot to guess
that the 2009 update is probably based on 2.0.2.
That being said, we are close to getting 1.1 out the door and we have
found a quick little hack that will make it work out of the box with
existing templates (previously it required a change to the
templates).  As soon as we get this done, Fusion 1.1 can be used as a
drop-in replacement for existing MapGuide installations up to 2.0.2
(not sure about MGE).
It seems likely, however, that MapGuide 2.1 will be based on the
Fusion SVN trunk version which will become Fusion 2.0 shortly.  This
version will contain all the improvements in 1.1 plus a raft of
performance improvements funded by Autodesk.  Given how release cycles
go, it will likely be a couple of months before MapGuide 2.1 is final
though.
Cheers
Paul
On 24-Oct-08, at 5:30 AM, Maksim Sestic wrote:
> Nope, I'm tied to MGE 2009 :-) But Autodesk finally released an
> Update to it
> which I'm currently installing. I hope it contains 1.1 RC1 patches
> too. Is
> it (I mean - Fusion part) OK now?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac
> Spitzer
> Sent: Friday, October 24, 2008 11:14
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] google maps as base layer
> have you tested 1.1 RC1 out yet?
> On Fri, Oct 24, 2008 at 8:03 PM, Maksim Sestic <max at geoinova.com>
> wrote:
>> Oh, I thought it was based on some custom JS mapping
>> implementation...
>> based on number of reported bugs :-) Since OpenLayers is rock solid -
>> why Fusion is not, then?
>> Spitzer
>> Sent: Friday, October 24, 2008 10:56
>> fusion wraps around openlayers and uses some other libraries as well
>> z
>> On Fri, Oct 24, 2008 at 7:46 PM, Maksim Sestic <max at geoinova.com>
>> wrote:
>>> Does it? I thought that Fusion uses it's own JS mapping
>>> implementation (based on other OS JS components outthere).
>>> ________________________________
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
>>> Skovhede, GEOGRAF A/S
>>> Sent: Friday, October 24, 2008 09:50
>>> Just to clarify:
>>> Maestro does not use OpenLayers, but Fusion does.
>>> Regards, Kenneth Skovhede, GEOGRAF A/S
>>> ed57gmc-bus at yahoo.com skrev:
>>> Yes, that's one of the "bits" I found, but still, not the exact
>>> steps
>>> to get it into mg. Keneth mentioned Maestro uses OL, but not how. I
>>> just haven't had the time lately to figure out those steps. When I
>>> do,
>> I'll post them.
>>> For now, I just thought it interesting to note the differences
>>> between the services. There may be others on the programming side,
>>> but for me, the content is a big item. The other reason, I'm trying
>>> to do this in mg and not their api, is the lack of navigation
>>> using their
> controls.
>>> e.g. zoom previous and zoom window. I also, will want to save the
>>> user's last view between sessions. This seems to be easer in mg/ol.
>>> Ed Jobe
>>> ----- Original Message ----
>>> From: Zac Spitzer <zac.spitzer at gmail.com>
>>> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
>>> Sent: Thursday, October 23, 2008 9:05:49 AM
>>> you can only integrate them using openlayers, any other approach
>>> will
>>> probably violate the terms of service (at least with google), unless
>>> your overlaying mapgudie stuff with their api
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>> signature database 3550 (20081023) __________
>>> The message was checked by ESET NOD32 Antivirus.
>>> http://www.eset.com
>>> http://www.eset.com
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
>> http://www.eset.com
>> http://www.eset.com
> Zac Spitzer -
> +61 405 847 168
> signature
> http://www.eset.com
> signature
> http://www.eset.com
