Re[mapguide-users] project Raster
Fri Oct 24 11:35:43 EDT 2008
Don MacGregor wrote:
> Frank,
> I find the link you sent very useful. I am not sure about the EPSG code of
> 10TM projection (NAD_1983_10TM_AEP_Resource) but the rest of the parameters
> are,
> PROJCS["NAD_1983_10TM_AEP_Resource",GEOGCS["GCS_North_American_1983",
> DATUM["D_North_American_1983",
> SPHEROID["GRS_1980",6378137.0,298.257222101]],
> PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],
> PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",0.0],
> PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-115.0],
> PARAMETER["Scale_Factor",0.9992],PARAMETER["Latitude_Of_Origin",0.0],
> UNIT["Meter",1.0]]
Don,
It should be possible to specify this as the target projection to gdalwarp
using:
  -t_srs '+proj=tmerc +lon_0=-115 +k=0.9992 +datum=NAD83'
Best regards,
