Re[mapguide-users] project Raster
Fri Oct 24 14:41:03 EDT 2008
Don MacGregor wrote:
> Many thanks Frank for your prompt reply,
> I am getting an error while running the following command using FWTools
> Shell;
> gdalwarp -t_srs '+proj=tmerc +lon_0=-115 +k=0.9992 +datum=NAD83'
> raw_spot.tif utm11.tif
> (while raw_spot.tif file in my bin folder)
> ERROR 1: Translating source or target SRS failed:
> '+proj=tmerc
Don,
On windows you should use double quotes around the coordinate system.
Try:
gdalwarp -t_srs "+proj=tmerc +lon_0=-115 +k=0.9992 +datum=NAD83"
Best regards,
