[mapguide-users] lack of MrSid - MGOS2.0.2
djonio djonio at miami-airport.com
Fri Oct 24 14:42:18 EDT 2008
Howdy,
Trying to use MrSID on MGOS2.0.2 - Windows 2003 Server sp2 - MapGuide Studio
2009
I installed and followed these instructions.
FDO 3.3.0 / MapGuide 2.0.0
This version uses the standard Visual C 2005 GDAL plugins:
http://home.gdal.org/dl/gdal14_vc8/
There are three files in this directory:
ecw_plugin_gdal14_vc8.zip : ECW GDAL Plugin
mrsid_plugin_gdal14_vc8.zip : MrSID GDAL Plugin
gdal144_vc8_sdk.zip : Do NOT download, not required for MapGuide or FDO.
Each file contains a "gdalplugins" folder, as well as some dlls in the root
of the zipfile. To install these plugins into MapGuide, you need to:
Extract the zipfile to a temporary location
Copy the "gdalplugins" folder to the MapGuide installation directory under
Server/Bin/
Copy the dll files that unzipped into the root of the temporary location to
the MapGuide installation directory under Server/Bin/Fdo/
The final location for the ECW files should look something like this:
 Server/Bin/Fdo/libecwj2.dll
 Server/Bin/gdalplugins/gdal_ECW.dll
And for the MrSID files, like this:
 Server/Bin/Fdo/lti_dsdk_cdll.dll
 Server/Bin/Fdo/lti_dsdk_dll.dll
 Server/Bin/gdalplugins/gdal_MrSID.dll
1 Configure a Feature Resource using the Generic Editor
2 Provider says OSGeo.Gdal
3 Connection Property set correctly
4 pointed it to the file
5 Test Connection is Successfull
6 Set the Override
Does NOT render in preview ... nada ... thoughts?
r,
dennis
View this message in context: http://www.nabble.com/lack-of-MrSid---MGOS2.0.2-tp20155679p20155679.html
