[mapguide-users] DWGLoadProcedure
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sun Oct 26 07:01:48 EDT 2008
To convert data to SDF, you must use the FDO libraries.
I think the FDO toolbox can do this for you, and if not, it's open
source, so you can use it as a starting point:
http://code.google.com/p/fdotoolbox
By "Set the coordinate system", do you mean coordinate system override?
If so, you can look at how Maestro does this:
http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/Maestro/ResourceEditors/CoordinateSystemOverride.cs#L256
I'm not quite sure how SHP files work, but I think you have to add the
.dbf to the featuresource as well,
ea. add these lines:
using (System.IO.FileStream fss =
System.IO.File.OpenRead("C:\\Hydrant.dbf"))
    con.SetResourceData(resId, "ShapeFile.DBF", ResourceDataType.File, fss);
And the SHP provider should pick it up. Repeat for any extra files you
want (ea. index files, etc.)
Regards, Kenneth Skovhede, GEOGRAF A/S
Greenhough, Jamie skrev:
> Thanks Kenneth(!!),
> I've implemented your code snippet, and it now looks like this:
>             string username = "Author1";
>             string password = "Author1";
>             string locale = "EN";
>             string url = "http://mapguideserver/MapGuide";
>             System.Uri uri = new System.Uri(url);
> ServerConnectionI con = new HttpServerConnection(uri, username,
> password, locale, false);
>             FeatureSource fs = new FeatureSource();
>             fs.Provider = "OSGeo.SHP.3.3";
>             fs.Parameter = new NameValuePairTypeCollection();
>             fs.Parameter["DefaultFileLocation"] =
> "%MG_DATA_FILE_PATH%ShapeFile.SHP";
>             string resId = "Library://MYNEWTESTSHAPE.FeatureSource";
>             con.SaveResourceAs(fs, resId);
> System.IO.File.OpenRead("C:\\Hydrant.shp"))
>                 con.SetResourceData(resId, "ShapeFile.SHP",
> ... and that works.
> Now I'm looking at and thinking about how to:
> o   *Convert to SDF feature source.*
> o   *Set the coordinate system.*
> o   *Import/save the attribute data from *.dbf file.*
> So I'm looking for more direction/information on uploading shp files
> to a managed mapguide server. Anyone?
> Thanks
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* Friday, October 17, 2008 1:00 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] DWGLoadProcedure
> As DWG is a proprietary format, I belive it will be difficult to do
> this with only open-source software.
> Supposedly, you can use FME to do it, and I think there is some
> organisation that has a 'open-source' like library for reading DWG data.
> There are no methods for dealing with DWG in Maestro or the Maestro
> API, for the above reasons.
> As for SHP, it is fairly easy to do this:
> IServerConnection con = new HttpServerConnection(url, username,
> fs.Provider = "OSGeo.SHP.3.3"; //Adjust if you are not using FDO 3.3
> fs.Parameter = new NameValueCollection();
> "%MG_DATA_FILE_PATH%ShapeFile.SHP"; //Can use absolute path here
> string resId = "Library://MyShpFile.FeatureSource";
> using(System.IO.FileStream fs =
> System.IO.File.OpenRead("C:\\myshapefile.shp"))
>     con.SetResourceData(resId, "ShapeFile.SHP", ResourceDataType.File,
> fs);
> The above code will create a managed copy of your shape data.
> If you want an unmanaged copy, just change "DefaultFileLocation" to
> the absolute path, and remove the "SetResourceData" call.
> Hello again MapGuide coders ;)
> I want to programmatically load .dwg/.shp files to a managed MapGuide
> environment.
> I think this can be accomplished with the MapGuide Studio API... but
> are there any other ways to get this data into the MapGuide server?
> I'm trying to stay open source. Are there any methods in the Maestro
> API to accomplish this?
> ----Notice Regarding Confidentiality----
> This email, including any and all attachments, (this "Email") is
> intended only for the party to whom it is addressed and may contain
> information that is confidential or privileged. Sierra Systems Group
> Inc. and its affiliates accept no responsibility for any loss or
> damage suffered by any person resulting from any unauthorized use of
> or reliance upon this Email. If you are not the intended recipient,
> you are hereby notified that any dissemination, copying or other use
> of this Email is prohibited. Please notify us of the error in
> communication by return email and destroy all copies of this Email.
> Thank you.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> Thank you.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081026/cf84f9bb/attachment.html
