[mapguide-users] Could it be MGOS2.0.2 - maybe needs some tuning?
Jason Birch Jason.Birch at nanaimo.ca
Tue Oct 28 12:04:19 EDT 2008
Hi Dennis,
If you can find time, I would suggest figuring out whether it is the
raster or vector layer that is causing problems.  If it is the vector
layer, then it's possible that Haris will be able to replicate the
problem (given appropriate source data).  If it's raster, well I think
we're currently a bit stuck because Frank doesn't have enough experience
with MapGuide internals to troubleshoot, and apparently nobody with core
MapGuide development experience has resources available to sit in a room
with him to figure out what is causing the problems.
In either case, if the problem is specific to your data and is not
reported with enough detail that it can be fixed, it is unlikely to be
addressed for 2.1, which is due out in alpha real soon now.
Jason
-----Original Message-----
Subject: RE: [mapguide-users] Could it be MGOS2.0.2 - maybe needs some
tuning?
Yes, that is what I am using. I guess I need to take the time and do
one-thing-at-once or bail out completely for now ... I guess I had
assumed too much about the "vitality" of this release.
