[mapguide-users] Can anybody help with iframes?
Chris Claydon chris.claydon at autodesk.com
Wed Oct 29 10:27:16 EDT 2008
As you've noticed, using height="100%" doesn't make the iframe fill the browser window height. You can either change it to a sensible size in pixels, if that works for your particular use case, or you can write some javascript to resize the frame. I found a posting on how to do this here:
http://brondsema.net/blog/index.php/2007/06/06/100_height_iframe
Chris.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of jamesdudden
Sent: Wednesday, October 29, 2008 7:38 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Can anybody help with iframes?
I have my map in an iframe - the problem is that it only displays part of
the screen (see below image attached) my code for this is as follows:
<iframe marginheight=0 marginwidth=0 frameborder=0 width="100%"
height="100%" scrolling="no"
src="http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fSSE%2fWeb+layouts%2fBlxo37002sht1+Web+Layout.WebLayout&LOCALE=en&USERNAME=Anonymous&PASSWORD="></iframe>
Does anybody know what is going wrong?
I am using MG2, windows 2003 server, .Net environment and Ajax viewer.
Regards
http://www.nabble.com/file/p20227294/map.jpg
Straightforward solutions to take care of your business
http://www.software-matters.co.uk Software Matters
View this message in context: http://www.nabble.com/Can-anybody-help-with-iframes--tp20227294p20227294.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
