[mapguide-users] enterprise 2008 on laptop
AmyN amy.norcott at cardno.com.au
Wed Oct 29 20:56:10 EDT 2008
they are running DHCP so the IP address is the same every time its starts up.
IIRC, the problem is that you get a new IP when you move the machine.
You should be able to restart the MapGuide service to fix it.
Another solution would be to install the MS loopbackadapter:
http://support.microsoft.com/kb/839013
Then set the loopback adapter to use a fixed adress, and it should work
(it does for me).
Regards, Kenneth Skovhede, GEOGRAF A/S
Amy Norcott
GIS Analyst
Wollongong, Australia
View this message in context: http://www.nabble.com/enterprise-2008-on-laptop-tp20179743p20238982.html
