[mapguide-users] Is it possible to publish a session layer as WMS ?
carls carlshe at 163.com
Wed Oct 29 22:05:23 EDT 2008
What I meant is whether it is possible to add a function to next version of
MG OS for publishing a session-layer in WMS.
Maybe MG OS team can have a new RFC about it.
>> No. You have to save layers to the Library repository in order to access
>> them via WMS. The reason for this is that the mapagent binary expects to
>> find the layers there.
>> Carl wrote:
>>>  I now use MG OS + Openlayers to develop a WebGIS system.
>>> I defined a basic map as base layer, and want to use a dynamic layer (
>>> for
>>> example, clone a existing layer and modify its filter).
>>> Normally, it seems I should define a runtimemap wraping the cloned
>>> layer.
>>> Yes, I tried it. But with openlayers, if the mapguide layer is used as
>>> overlayer, there will always be a 'access denied' message shown. I have
>>> had
>>> a post about the MapGuide overlayer with Openlayers.
>>> (http://n2.nabble.com/Access-denied-for-MapGuide-Overlayer-%28with-patched-MapGuide.js%29-tt1307180.html#a1307180)
>>> So I intend to use the Mapguide WMS. It seems MapGuide can only publish
>>> a
>>> predefined layer as WMS.
>>> Thanks!
>>> Regards, Carl SHE
>>> View this message in context:
>>> http://n2.nabble.com/Is-it-possible-to-publish-a-session-layer-as-WMS---tp1386781p1386781.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Is-it-possible-to-publish-a-session-layer-as-WMS---tp20206768p20233889.html
Regards, Carl SHE
View this message in context: http://n2.nabble.com/Is-it-possible-to-publish-a-session-layer-as-WMS---tp1386781p1396525.html
