[mapguide-users] Is it possible to publish a session layer as WMS ?
Zac Spitzer zac.spitzer at gmail.com
Thu Oct 30 05:34:22 EDT 2008
given that wms isn't cached you might as well use a normal dynamic mapguide
layer
as neither are cached
have you tried using the native openlayers support for mapguide dynamic
layers?
z
On Thu, Oct 30, 2008 at 8:01 PM, Kenneth Skovhede, GEOGRAF A/S <
ks at geograf.dk> wrote:
>  You can request this by creating a ticket.
> If you want to speed it along, you can create an RFC,
> but that requires some serious work regarding the
> eventual implementation. This in turn requires
> a lot of knowledge about the MapGuide inner workings.
> Another option is to fund someone to build it and submit it.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> carls skrev:
> What I meant is whether it is possible to add a function to next version of
> MG OS for publishing a session-layer in WMS.
> Maybe MG OS team can have a new RFC about it.
>  No. You have to save layers to the Library repository in order to access
> them via WMS. The reason for this is that the mapagent binary expects to
> find the layers there.
> Carl wrote:
>   I now use MG OS + Openlayers to develop a WebGIS system.
> I defined a basic map as base layer, and want to use a dynamic layer (
> for
> example, clone a existing layer and modify its filter).
> Normally, it seems I should define a runtimemap wraping the cloned
> layer.
> Yes, I tried it. But with openlayers, if the mapguide layer is used as
> overlayer, there will always be a 'access denied' message shown. I have
> had
> a post about the MapGuide overlayer with Openlayers.
> (http://n2.nabble.com/Access-denied-for-MapGuide-Overlayer-%28with-patched-MapGuide.js%29-tt1307180.html#a1307180)
> So I intend to use the Mapguide WMS. It seems MapGuide can only publish
> a
> predefined layer as WMS.
> Thanks!
> Regards, Carl SHE
> View this message in context:http://n2.nabble.com/Is-it-possible-to-publish-a-session-layer-as-WMS---tp1386781p1386781.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context:http://www.nabble.com/Is-it-possible-to-publish-a-session-layer-as-WMS---tp20206768p20233889.html
> Regards, Carl SHE
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081030/0c689f3e/attachment.html
