[mapguide-users] selectAggregate error
Jason Birch Jason.Birch at nanaimo.ca
Thu Oct 30 11:16:25 EDT 2008
If you have a reproducible issue, I would strongly encourage you to file
a ticket against it:
http://trac.osgeo.org/mapguide/wiki/SubmitTicket
Please ensure that you provide enough information and data for the
developers to _easily_ reproduce the problem.  Preferably an MGP that
contains all of the data and data/layer/map definitions they will
require, along with external data in something like an Access database
and the name of the ODBC connection being used.  If the problem requires
a lot of work to reproduce, it is less likely to receive attention.
Jason
-----Original Message-----
Subject: Re: [mapguide-users] selectAggregate error
I have tested with different formats: unmanaged, managed shapes, managed
sdf
and unmanaged sql 2008 feature sources. As well I have tested in
different
viewers: Fusion and Ajax viewer. In all the cases the theming is wrong.
Could it be registered as an issue?
