[mapguide-users] RE: two requests
Dave Wilson dave.wilson at autodesk.com
Fri Oct 31 18:15:47 EDT 2008
I was concerned that any code in the Web Layout that gets served to the client may have been cached, but that appears not to be the issue. The two requests was originally an issue in IE6 because IE doesn't handle the transparency in the PNG image so it would fail and then send a second request to resolve the problem.
You can also just look at the Access.log for MapGuide and you will either see 1 or 2 RenderDynamicOverlay requests if I am not mistaken.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Friday, October 31, 2008 4:18 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] RE: two requests
I checked and It was already set to "Every time I visit the webpage".
Although I don't see how that would be reason for generating two requests to MG.
I also tried to find example of transparent PNG and I viewed it in IE 7. I used Fiddler and I can see only one request send for that png while when accessing MapGuide site I can see two requests send to MG.
Haris
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Friday, October 31, 2008 10:19 PM
Check to ensure your browsers are not caching stuff.
Tools\Internet Options\General\Browsing History - Settings\"Every time I visit the webpage"
Dave
Sent: Friday, October 31, 2008 3:38 PM
I believe all same windows updates are done on all machines.
I checked also that same IE 7 version is installed 7.0.5730.13 on all machines.
Thanks,
Haris
Sent: Friday, October 31, 2008 10:09 PM
Subject: [mapguide-users] RE: two requests
I don't know what the cause of the behavior could be, but is it possible that the same Windows Updates have not been applied to the machines sending 2 requests?
Dave
Sent: Friday, October 31, 2008 3:23 PM
Subject: [mapguide-users] two requests
In Autodesk MapGuide Enterprise Update 1 Readme, I found this interesting:
"■ FDO Oracle trace showed two sets of queries for a single layer when there
should have been only one. Web browsers were sending a second render
map request because of PNG transparency issues with the map image.
Internet Explorer 7, Firefox 2 and Firefox 3 now only send one request,
improving performance. Internet Explorer 6 and Safari 3 still send two
requests to render the map, because they do not properly support PNG
transparency."
I noticed that ajax viewer on one of my PCs is sending two requests to Mapguide 2.0.2. even when I am using IE 7.
So it makes map rendering twice slower as it should be.
FF 2 sends only one request from that machine.
>From couple of other PCs, IE 7 is sending only one request.
Is this only PNG transparency issue or there are some other issues?
Haris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081031/c15b0f23/attachment.html
