[mapguide-users] invokeURL FUSION only works fine from mgstudio
Chris Claydon chris.claydon at autodesk.com
Tue Sep 2 22:43:28 EDT 2008
Hi Rodolfo,
Sorry for the slow response getting back to you. If you sent an attachment, it didn't make it through to the mailing list.
Perhaps you could just copy the XML right into your email.
Chris.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rodolfo Moreno
Sent: Wednesday, August 27, 2008 9:12 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] invokeURL FUSION only works fine from mgstudio
Hi Chris,
I am sending the xml of my flexible layout. you have to launch the map from
the index.html file in order to get the error that I mentioned.
Chris Claydon wrote:
> Can you save your flexible web layout as XML and send it to us? (MG Studio
> has a function to save as XML) I'd like to try to reproduce the problem.
> Chris.
> Moreno
> Sent: Tuesday, August 26, 2008 4:33 PM
> Subject: [mapguide-users] invokeURL FUSION only works fine from mgstudio
> I am using an invokeURL widget. When my map is launched from mapguide
> studio
> 2009 the SESSIONID and MAPNAME parameters are sent without errors to the
> mapguide server, however when the map is launched from the index.html
> directly these parameters are sent twice.
> Request["MAPNAME"] = MyMap48b483ff318e5,MyMap48b483ff318e5
> is it a issue of fusion?
> Regards
> Rodolfo Moreno
> CivilEng
> http://n2.nabble.com/invokeURL-FUSION-only-works-fine-from-mgstudio-tp785418p785418.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://n2.nabble.com/file/n787259/VentanillaFlexibleLayout.ApplicationDefinition.xml
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/invokeURL-FUSION-only-works-fine-from-mgstudio-tp785418p787259.html
