[mapguide-users] How to enable markup using Design review
Scott Hameister scotth at mpowerinnovations.com
Thu Sep 4 18:24:55 EDT 2008
ANYBODY WORKING ON THIS OR IS THERE A FIX FOR THIS and Why is the ticket so
Old and of a low importance this is a huge functionality???
I utilized The EPLOT code to output a Mapguide AJAX map out to DWF using
mappingService.GeneratePlot and When I am able to mark the map up in Design
Review but unfortunately measure is useless as well as roundtriping back
into a DWG is useless NEITHER WORK...it obviously does not send out
georeferenced information as does map when you Plot...Another Oddball
occurunce it will publish data on only the topmost layer to have data
attributes and no others...Man This is SO CLOSE TO PERFECT FOR ROUND
TRIPPING DATA...PLease Someone Fix This...I have Customers Who desperately
hold their collective breaths for such a solution for once
JasonBirch wrote:
> Joel,
> I have an enhancement request for this item in the MapGuide Open Source
> Trac.  Can you please add your comments to this item?
> http://trac.osgeo.org/mapguide/ticket/144
> You may need to create an OSGeo UserID before editing this page, details
> are here:
> http://www.osgeo.org/osgeo_userid
> Thanks,
> Jason
> -----Original Message-----
> From: Joel Carranza
> Subject: [mapguide-users] RE: How to enable markup using Design review
> However, is there a way to generate a DWF out of the MapGuide which is
> more "geo-aware", which contains inside the DWF information about the
> map extent which the DWF covers, and where ADR can make use of tools
> like Measure and their geo-referencing ability?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/How-to-enable-markup-using-Design-review-tp8598618p19321268.html
