[mapguide-users] How to enable markup using Design review
Zac Spitzer zac.spitzer at gmail.com
Thu Sep 4 20:48:12 EDT 2008
Scott,
You know it's this an open source project, if you have customers who want
it, have you
considered putting some resources YOURSELF into fixing this problem on
behalf
of your customers?
z
On Fri, Sep 5, 2008 at 8:24 AM, Scott Hameister <
scotth at mpowerinnovations.com> wrote:
> ANYBODY WORKING ON THIS OR IS THERE A FIX FOR THIS and Why is the ticket so
> Old and of a low importance this is a huge functionality???
> I utilized The EPLOT code to output a Mapguide AJAX map out to DWF using
> mappingService.GeneratePlot and When I am able to mark the map up in Design
> Review but unfortunately measure is useless as well as roundtriping back
> into a DWG is useless NEITHER WORK...it obviously does not send out
> georeferenced information as does map when you Plot...Another Oddball
> occurunce it will publish data on only the topmost layer to have data
> attributes and no others...Man This is SO CLOSE TO PERFECT FOR ROUND
> TRIPPING DATA...PLease Someone Fix This...I have Customers Who desperately
> hold their collective breaths for such a solution for once
> JasonBirch wrote:
> > Joel,
> > I have an enhancement request for this item in the MapGuide Open Source
> > Trac.  Can you please add your comments to this item?
> > http://trac.osgeo.org/mapguide/ticket/144
> > You may need to create an OSGeo UserID before editing this page, details
> > are here:
> > http://www.osgeo.org/osgeo_userid
> > Thanks,
> > Jason
> > -----Original Message-----
> > From: Joel Carranza
> > Subject: [mapguide-users] RE: How to enable markup using Design review
> > However, is there a way to generate a DWF out of the MapGuide which is
> > more "geo-aware", which contains inside the DWF information about the
> > map extent which the DWF covers, and where ADR can make use of tools
> > like Measure and their geo-referencing ability?
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/How-to-enable-markup-using-Design-review-tp8598618p19321268.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080905/0cd4da0c/attachment.html
