[mapguide-users] Deploying custom tool for multiple projects
poy poychris at gmail.com
Fri Sep 5 10:29:25 EDT 2008
Hi All,
I have developed a generic tool which I would like to use for multiple
projects. The generic tool is an asp.net application which I will load using
Invoke URL command.
All my projects are hosted in a web server. eg. http://proj1.mycompany.com,
http://proj2.mycompany.com. Both these websites have to use the generic
tool. So, my question is can I deploy my generic tool to the server only
once and reuse it using the Invoke URL command? I tried it but the tool
works only when it is deployed within the project specific locations. For
eg., I need to deploy the tool once within the proj1 directory and again
within the proj2 directory for the tool to work with both the websites.
In simple terms, when I invoke the generic tool based on some application
logic, the tool will finally zoom in to a particular location on the map.
So, I will use the Viewer's ZoomToView command. To do this, I will get the
handle of the viewer frame. I am unable to do this when the tool is not
deployed within the project directory.
Is there a feasible solution or am I failing to understand something here?
Thanks for your time.
poy
View this message in context: http://www.nabble.com/Deploying-custom-tool-for-multiple-projects-tp19332497p19332497.html
