[mapguide-users] mgstudio 2009 Installation problem on vista
Darrin Maidlow dmaidlow at landorgis.com
Sat Sep 6 01:55:55 EDT 2008
Hi Rodolfo,
Is your Vista machine running the 64 bit version of Vista?  If so, you
cannot install Studio on that machine.  I tried changing the .ini file
similar to what can be done with AutoCAD Map and Studio will install - but
it crashes as soon as you run it.  I've had to resort to a virtual machine
running a 32 bit OS.
darrin
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rodolfo Moreno
Sent: Friday, September 05, 2008 9:54 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] mgstudio 2009 Installation problem on vista
Hi all,
I am having a problem during the installation process.
I have installed mgstudio 2009 trial version on window server 2003 sp2
without problem, however when I tried to install on window vista I got an
error message on the first time. In my second attemp the link showed up
disabled, which is why I couldn't got the accurate error message.
I will appreciate any suggestion.
Rodolfo Moreno
CivilEng
View this message in context:
http://n2.nabble.com/mgstudio-2009-Installation-problem-on-vista-tp841474p84
1474.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
