[mapguide-users] Adjusting subsequent views
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sat Sep 6 12:54:56 EDT 2008
I'm sure it can be done.
However, it seems fairly advanced.
I would suggest that you have a look at OpenLayers:
http://openlayers.org
With OpenLayers, you can have your MapGuide map as a base layer,
and then put an overlay with your custom layer.
You can then override the mapagent path in the overlay to point to your
customization page, rather than mapagent.fcgi.
If you want to stick with the WebLayout based you will most likely get
better results with a manually added overlay image.
The problem with the manual approach is passing on events to the image
below.
Another option would be to have all calls to mapagent.fcgi point to your
PHP script, and then make the script
act as a relay page for those calls that you are not interrested in.
Regards, Kenneth Skovhede, GEOGRAF A/S
gingerbbm skrev:
> OK, I understand that I can grab the runtime map and use the API to alter it.
> The question is, where do I put the code to do this? For the Ajax viewer
> I've traced the code to JavaScript in ajaxmappane.templ, where functions
> like Pan() end up calling RequestMap(). But RequestMap() posts to
> mapagent.fcgi - in other words an impasse.
> My current idea is to put a synchronous call to a bespoke PHP during the
> relevant JavaScript functions (such as Pan()) which will alter the runtime
> map. When control returns to the JavaScript, RequestMap() will ultimately be
> called and thus display my altered map.
> Do this sound feasible? :confused:
