[ZS1] Re: [mapguide-users] MS SQL and SDF Join Problem
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Sep 12 03:20:37 EDT 2008
Try linking the tables with integer columns, that is usually the only
stable solution.
Regards, Kenneth Skovhede, GEOGRAF A/S
anakando skrev:
> Yes..my MG version is 2.0.1..Here is my situation. I have database that
> contain 2 tables (as example). Both of tables are linked to SDF file using
> unique id,and both data type are set to 'varchar'. Out of my curiosity, only
> 1 table are successfull linked to sdf, but the other one are not. It only
> show the first row of data.I am frustated
> zspitzer wrote:
>> also which version are you running 2.0.1?
>> On Fri, Sep 12, 2008 at 2:54 PM, Jackie C. Ng
>> <jumpinjackie at gmail.com>wrote:
>>> Are you joining on strings?
>>> - Jackie
>>> anakando wrote:
>>>> Hi guys..
>>>> I faced a very big problem (i guess) since i cannot overcome this
>>> problem
>>>> for almost 2 weeks! Let me simplify my problem. I have successful makes
>>> a
>>>> join between my sdf file and MS SQL, but the problem is,after
>>> joining,it
>>>> only show only first row data form MS SQL. The type of join is inner
>>> join,
>>>> and relationship with secondary records is one-to-one. But when i
>>> change
>>>> type of join to left outer join, it will show all the data from MS SQL
>>> but
>>>> with a 'null' value! I have do some research about this problem but i
>>>> can't find something useful for me. If somebody out there already
>>>> experienced and successful solved the problem, please let me know. TQ
>>> http://themapguyde.blogspot.com
>>> http://www.linkedin.com/in/jackieng
>>> View this message in context:
>>> http://www.nabble.com/MS-SQL-and-SDF-Join-Problem-tp19448719p19449417.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080912/d2f26c83/attachment.html
