[mapguide-users] Making MapGuide JSP to work with IIS (the missing link -- almost there!)
inspiron2 vistav20 at yahoo.com
Mon Sep 15 07:44:10 EDT 2008
OK, guys, I figured it all out. It works!
Here is what was wrong:
Had to add "/mapguide/mapviewerjava/*=worker1" to uriworker file. I could
only figure it out after tracing through the source samples.
If anyone's interested, following is what is required to be in the uriworker
file to make Java samples work in IIS:
/mapguide/javaviewersample/*=worker1
/mapguide/javasamples/*=worker1
/mapguide/mapviewerajax/*=worker1
One other observation: if you download Tomcat from Apache website,
isapi_redirect.dll just doesn't work in that (IIS 6). Had to install Tomcat
as part of MapGuide install, and isapi_redirect.dll had no problem working
with Tomcat shipped as part of MapGuide.
ciao
inspiron2 wrote:
> Further to my last post asking for help:
> I spotted an error in the uriworker.properties file. I wasn't putting in
> an "=" sign in between the alias and worker. I fixed that, and that made
> the JSP's work. But, the map etc still doesn't function. I don't even get
> a skeleton page. Error messages indicate that all MapGuide related
> references could not be resolved while compilting JAVA files.
> From previous experience of working with JSP's, such errors may indicate
> that class_path available to MapGuide JSP's can't resolve MapGuide related
> declares. But how do I fix that.
> The only difference between this non-working version and the working
> version is that the working one is called through Apache, and the
> non-working one is being called from IIS 6. All files etc are EXACTLY the
> same (i.e. the same files, not just copies of same files).
> thx
> inspiron2 wrote:
>> Hi,
>> I am trying to make MapGuide open source work with IIS, and using JSP
>> (java) as development language.
>> I am able to make MapGuide Java (JSP) work in Tomcat + Apache.
>> ajaxViewersample.jsp and ajaxtiledviewersample.jsp work just fine.
>> Also, I am able to make Tomcat work with IIS 6 in Windows 2003. The ISAPI
>> redirect DLL loads fine, and I am able to execute all JSP examples.
>> I am also able to configue IIS + PHP manually. PHP samples and Site Admin
>> work fine under IIS 6 (W 2003 SP2 standard).
>> What I am not able to figure out is how to make MapGuide's java side
>> (i.e. JSP) work with IIS. Here is what I have done so far: (IIS 6 + W2003
>> standard SP2)
>> As described above, successfuly integrated isapi_redirect.dll into IIS,
>> and it run's Tomcat's JSP examples just fine. Note: Tomcat is installed
>> by the MapGuide install program in it's default location (C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\Tomcat), and since
>> MapGuide install doesn't include JSP example files, I had to copy the
>> example files into the C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\Tomcat\webapps\examples
>> directory.
>> Created a new Web Service Extension in IIS. extension: mapagent; pointed
>> it to isapi_MapAgent.dll in www\mapagent directory. The status is
>> "Allowed"
>> Created an application called "mapguide" in IIS under the Default Web
>> Site, and pointed it to the www directory. Execute permissions are
>> "Scripts adn Executables". An extension ".php" was defined under it's
>> configuration, and the executable picked was php5isapi.dll in Php
>> directory.
>> Created an application called "mapagent" in IIS under the above created
>> mapguide application. It's dir was pointed to \mapguide\mapagent, and it
>> also had "Scripts and Executables" permission. Under it's configuration,
>> an extension ".fcgi" was created and linked to isapi_MapAgent.dll
>> executable.
>> At this point:
>>  - PHP based site admin (for MapGuide) worked fine!
>> (http://localhost/mapguide/mapadmin/login.php)
>>  - MapAgent worked fine.
>> http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library://&TYPE=&DEPTH=-1
>> resulted in an XML document following a user-id/password prompt.
>>  - Web Extensions worked fine.
>> http://localhost/mapguide/mapviewerajax/ajaxviewer.php?WEBLAYOUT=Library://ATest.WebLayout
>> and
>> http://localhost/mapguide/mapviewerajax/ajaxviewer.aspx?WEBLAYOUT=Library://ATest.WebLayout
>> gave the expected "Resource not found" message.
>> At this point, I created two virtual directories under "mapguide" level,
>> called them javaviewersample and javasamples, and linked them to
>> corresponding physical directories in the www folder.
>> The uriworkermap.properties files in the Tomcat conf directory contains
>> following lines:
>> /examples/*=worker1  <-- this one works, so I know that isapi_redirect
>> mechanism and Tomcat are working.
>> /mapguide/javaviewersample/* worker1
>> /mapguide/javasamples/* worker1
>> /mapguide/mapviewerajax/* worker1
>> When I try any of the following URL's, I get page not found error.  Any
>> ideas?
>> http://w2003/mapguide/javaviewersample/ajaxviewersample.jsp
>> http://w2003/mapguide/javaviewersample/ajaxtiledviewersample.jsp
>> http://w2003/mapguide/javasamples/index.jsp
>> http://w2003/mapguide/mapviewerajax/ajaxviewer.jsp?WEBLAYOUT=Library://ATest.WebLayout
>> I know that I am this close, but can't figure out the missing link. I can
>> guess that "examples" context is working because it is in Tomcat's
>> default location (i.e. Webapps) folder. But how do I make it work for
>> applications which are not in the default webapps folder, but others
>> (e.g. javasamples and javaviewersample). Or, may be, my problem lies else
>> where.
>> I WOULD REALLY APPRECIATE ANY HELP I COULD GET IN THIS REGARD!
>> THANKS!!!!!!
View this message in context: http://www.nabble.com/Making-MapGuide-JSP-to-work-with-IIS-%28the-missing-link----almost-there%21%29-tp19485081p19491403.html
