[mapguide-users] Extending the functionality of built-in commands (Ajax viewer)
gingerbbm stuart.jones at jacobs.com
Mon Sep 15 08:52:57 EDT 2008
Kenneth, you are a star.
I tweaked your code as follows to prove the visibility toggling:
    $map = new MgMap();
    $map->Open($resourceService, $mapName);
    $map->GetLayers()->GetItem(0)->SetVisible(true);
    $resId = new MgResourceIdentifier("Session:$sessionID//$mapName.Map");
    $resId->Validate();
    $map->Save($resourceService, $resId);
Ultimately I needed to change the feature class of a layer. To achieve this
I read in the LayerDefinition from the Library repository, edit the
FeatureName XML element in the desired manner, then write the modified
LayerDefinition to the Session repository, which I use in a
SetLayerDefinition() call on the relevant layer in the runtime map. And it
works a treat!
Thanks
Stuart
View this message in context: http://n2.nabble.com/Extending-the-functionality-of-built-in-commands-%28Ajax-viewer%29-tp841643p1090337.html
