[mapguide-users] Points not in correct place??
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Sep 16 05:42:02 EDT 2008
I have seen something that happend in MGOS 2.0, where the center of the
symbols were not being correctly used.
Instead of placing the center of the symbol at the point, the lower left
corner of the symbol is placed at the point.
I have not experimented further, or found a fix (and maybe something
else is wrong in my case).
You may also experience rounding problems, if you datasource has another
coordinate system than the map.
You can try to put up a "Coordinate System Override" on the
FeatureSource of the points, and make sure that it is excatly
the same as on the other layers.
Regards, Kenneth Skovhede, GEOGRAF A/S
Love, Bev (Capita Symonds) skrev:
> Hi all,
> I'm hoping this might be a simple problem to fix...
> I've been using Autodesk MapGuide 6.5 for the past couple of years and
> have had no real major issue with it, but am now looking at moving
> over to Open Source MapGuide.
> I'm busy playing around with Open Source MapGuide and am creating
> maps, with the same shape files that I used with MapGuide 6.5.
> I've created several layers which displays lines representing the
> roads in the county. I've then created another layer displaying points
> for all the towns in the county. I've also created another layer
> containing Ordnance Survey raster images. Straight forward and no
> problems. However, when I get all the layers on the same map, the
> points are slightly out and not displaying in the right place. The
> road layers and raster image layers, correctly match up but the point
> layer doesn't.
> Is there some way that I can set the central point for a layer, or has
> anyone come across this before??
> I've created the layers using MapGuide Maestro.
> Thanks in advance!!!
> Bev
> This email and any attachment are intended solely for the addressee,
> are strictly confidential and may be legally privileged. If you are
> not the intended recipient any reading, dissemination, copying or any
> other use or reliance is prohibited. If you have received this email
> in error please notify the sender immediately by email and then
> permanently delete the email. Copyright reserved.
> All communications, incoming and outgoing, may be recorded and are
> monitored for legitimate business purposes.
> The security and reliability of email transmission cannot be
> guaranteed. It is the recipient's responsibility to scan this e-mail
> and any attachment for the presence of viruses.
> The Capita Group plc and its subsidiaries ("Capita") exclude all
> liability for any loss or damage whatsoever arising or resulting from
> the receipt, use or transmission of this email.
> Any views or opinions expressed in this email are those of the author
> only.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080916/c8db0ea4/attachment.html
