[mapguide-users] PostGIS binaries
Jackie Ng jumpinjackie at gmail.com
Wed Sep 17 19:08:04 EDT 2008
2 things I notice:
1) MG 2009 uses FDO 3.3, yet your providers.xml entry uses 3.2 binaries.
2) I believe that PostGIS provider also needs to have PostGIS and PostgreSQL
binaries in the same path as the provider. See:
http://trac.osgeo.org/fdo/wiki/FdoPostGISNotes
- Jackie
Moog wrote:
> Hi,
> i downloaded PostGIS binaries from
> http://www.geomapgis.com/web/geomap-group/fdo/index.html
> put them into C:\Program
> Files\Autodesk\MapGuideEnterprise2009\Server\Bin\Fdo and modify
> providers.xml adding
>   <FeatureProvider>
>     <Name>OSGeo.PostGIS.3.2</Name>
>     <DisplayName>OSGeo FDO Provider for PostGIS</DisplayName>
>     <Description>FDO Provider for PostGIS</Description>
>     <IsManaged>False</IsManaged>
>     <Version>3.2.0.0</Version>
>     <FeatureDataObjectsVersion>3.2.0.0</FeatureDataObjectsVersion>
>     <LibraryPath>.\PostGISProvider.dll</LibraryPath>
>   </FeatureProvider>
> i use dependency walker i got the following warning for
> PostGISProvider.dll
> Warning: At least one module has an unresolved import due to a missing
> export function in a delay-load dependent module.
> i can't see PostGIS FDO provider while i'm trying to make a data
> connection
> at mapguide studio 2009. Any sugest?
> Best regards and thanks for your time,
> Fernando.
> http://www.nabble.com/PostGIS-binaries-tp19541494p19541494.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/PostGIS-binaries-tp1096595p1096850.html
