[mapguide-users] Themed layer works with Mge2008 and not in Mg 1.1.0
Jackie C. Ng jumpinjackie at gmail.com
Thu Sep 18 07:49:33 EDT 2008
MGE 2008, whose OS equivalent version is 1.2.0 had some new feature join
capabilities and improvements that may not have existed in 1.1.0 of the OS
version.
- Jackie
MacNair wrote:
> Hi,
> We have a SDF layer, themed based on string values in a field (viz.
> "Status") from SQL Server table. The primary key field in the same table
> (viz "FNo") is also an attribute that is used to join the features in SDF
> layer and the corresponding record in the database table.
> The application works fine with Mapguide Enterprise 2008 showing the
> themed SDF layer. But when the package is loaded on Mapguide 1.1.0, the
> themed layers don't show up.
> Is this case of a silly mistake?  Or was this issue discussed earlier? We
> don't see any threads discussing this though.
> Any help is appreaciated.
> Thanks!
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/Themed-layer-works-with-Mge2008-and-not-in-Mg-1.1.0-tp19511903p19551030.html
