[mapguide-users] Extra Query result
anakando anakando at yahoo.com
Thu Sep 18 20:36:43 EDT 2008
My search syntax is "ID = $USERVARIABLE". The problem is, when i trying to
search an ID (such as ID 007),it will return to me 2 results, ID 001 and ID
007. ID 001 is my first record in corresponding table in database. No matter
what value i search, i still getting ID 001 for the result.
Rock Beans wrote:
> The search usually adds a % on the end so a search of ID would produce
> more records. Can you be more specific in your issue?
> On Wed, Sep 17, 2008 at 8:56 PM, anakando <anakando at yahoo.com> wrote:
>> Hi guys. I was trying to use build-in search function into my project
>> sample.It is working but not so perfectly. It will show the result of the
>> query along with the 1st row of my data.For example,when i want to search
>> an
>> ID of "ID 007", then it will return "ID 001" and "ID 007". I also facing
>> this problem with query features module that contain in ajaxviewersample
>> folder.
>> View this message in context:
>> http://www.nabble.com/Extra-Query-result-tp19544605p19544605.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Extra-Query-result-tp19544605p19564251.html
