[mapguide-users] Problem with the example
Rock Beans rockbeans at gmail.com
Tue Sep 23 12:31:00 EDT 2008
Here is one geared towards the ASP viewer. The concept is similar to
PHP. You need to allow PHP/ASP within IIS to run which is done using
the IIS Manager. If you use PHP (which is used either way for the
MapAdmin) the PhpInfo page will help you get to the bottom if it is
working at all.
http://www.webrade.com/blogs/darrin/2008/05/01/ManuallyConfigureMapguide2009WebTierOnVistaX64IIS7.aspx
On Tue, Sep 23, 2008 at 10:35 AM, Dave Wilson <dave.wilson at autodesk.com> wrote:
> I don't believe the configuration out of the box works on Vista, specifically IIS7. There was a posting a while back with the steps on how to manually configure the web server. You will have to search for it.
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rock Beans
> Sent: Tuesday, September 23, 2008 9:31 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Problem with the example
> If you plop a PhpINFO page in the mapguide virtual directory does that
> run. Google phpinfo.
> On Tue, Sep 23, 2008 at 10:13 AM, Ahmed Ragab <elmasri.ahmed at gmail.com> wrote:
>> Dear All
>> I have installed map guide server and web server according to the getting
>> started
>> File , i have tried to runthe php examples but without luck , my system is
>> 32 bit vista
>> Appriciate any help
>> Regards
>> El masri
>> Awaiting your soonest reply and remain with best regards
>> Ahmed Ragab
>> Managing director
>> Nineteen tech.
>> Phone : +2 02 27273477
>> Fax : +2 02 27273476
>> Address: 8321 ring road , al hadaba al wasta ,
>> mokatam , beside karfour.
>> The information in this e-mail is confidential and may be legally
>> privileged. It is intended solely for the addressee. If you are not the
>> intended recipient, please destroy this message and notify us immediately.
>> Any disclosure, copying or distribution of this message is prohibited and
>> may be unlawful.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
