[mapguide-users] Re: MapGuide Open Source 2.0.2 released
Zac Spitzer zac.spitzer at gmail.com
Wed Sep 24 02:39:24 EDT 2008
Are you using oracle? EPSG:4019 is the defacto fall back when Mapguide
doesn't recognise
the SRID with oracle....
On Wed, Sep 24, 2008 at 4:30 PM, Francisco Javier Rojas Durán
<francisco.rojas at dasoft.com.mx> wrote:
> Hi Tom and Zac
> Since I have tested MGOS 2.0.2, I notice that for my data set there is still
> the defect with coordinate systems using WMS Feature Sources, which is
> described better on this post :
> http://www.nabble.com/WMS---coordinate-system-overriding-in-MGOS-2.0.1-fails
> -td17665380.html#a17665380
> So maybe for Zac , and other guys not using several WMS as Raster Feature
> Sources, should be more reliable the latest release than the previous ones.
> But why MGOS 2.0.2 does not contains a fix for Ticket 600 ->
> http://trac.osgeo.org/mapguide/ticket/600
> I notice that with MGEnt 2009 there is no problem for conversion (but there
> is another drawbacks) , I have a map with all layers based on LL / WSG 84
> EPSG:4326, and the message error that appears on MGOS Error.log is:
> The coordinate system (EPSG:4326) of layer XXXXXXXXXXX cannot be different
> than the coordinate system (EPSG:4019) of the map.
> The question is why, if there is virtually no Coordinate System Conversion,
> since all my data is based on that projection.
> Since MGEnt 2009 is based on MG 2.0.0.x and not on MGOS 2.0.1 and so on,
> when either a Service Pack for MGEnt 2009 will be available OR when a MGOS
> fix for the ticket #600 should be released, since because this issue and
> other ones (like the described on this post by Andy Morsell using MGOS 2.0.1
> http://www.nabble.com/MGE2009-crashing-tp19202309p19202309.html that still
> applies to MGEnt) I can't go on production environment for my web app based
> on MG technology either Open Source or Autodesk.
> Regards
> Francisco Javier Rojas Duran
> Date: Tue, 23 Sep 2008 11:57:16 +1000
> From: "Zac Spitzer" <zac.spitzer at gmail.com>
> Subject: Re: [mapguide-users] MapGuide Open Source 2.0.2 released
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Message-ID:
>        <7a85053e0809221857v7f920e6dqf6a8630c19c0dff6 at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> This release is really stable, I did some testing on the original test
> build and I managed to
> produce 30,000 tiles without a single error using managed SDF's.
> a big thanks to the development team for their effort on this one :)
> z
> On Tue, Sep 23, 2008 at 7:38 AM, Tom Fukushima
> <tom.fukushima at autodesk.com> wrote:
>> The MapGuide Open Source project team is pleased to make MapGuide Open
>> Source 2.0.2 available. This release contains support for Firefox 3, bug
>> fixes, rendering fixes and updated FDO DLLs. For the complete list of
> fixes
>> please see the release notes:
>> http://trac.osgeo.org/mapguide/wiki/Release/2.0/Notes.
>> The MapGuide team
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
